PVP to Micrologix 1000, is it possible?
LowRange
Jun 2016
Omaha
52
I'm working on learning how configure Factorytalk applications to communicate through serial to older controllers but I've only got a beat up old Mircologix 1000 and a PVP 6 400 in the shop to play with.
I'm having a helluva time at it. Is it possible for a PVP 6 400 to communicate through a 1761-CBL cable?
Interesting. I can see the Micrologix 1000 in the design tab under my DF-1 driver but when I hit the verify button the dialog box pops up stating that the Design path is not assigned. Serial is silly.
If you can see it in the network tree, then you should be good to connect to it. Not assigned probably just means you haven't actually assigned the seen device to your shortcut - click on the shortcut name, click on the PLC, and click apply. Then try verifying again.
The design path was assigned after I clicked on the shortcut as you stated. I have been able to test the application and turn output 0 on and off. Now, do I really want copy my design path to the runtime? With ethernet, sure, but I use comport 3 and auto configure when I connect the laptop to serial. Is that what I want for the PVP 6 400 and Micrologix 1000? I was under the impression that the runtime path for serial micrologix and SLC should be com port 1 without auto configure.
I have not been successful in getting the application to communicate with the Micrologix once downloaded to the PVP 6 400 with the attached Runtime configuration.
Good Afternoon All, I am hoping someone here will have some input to get me past this terrible hump. I have programmed Siemens 200 and now 1200...
2,818
Hello, I currently have a Micrologix 1400 PLC connected to PanelView Plus 600 HMI through ethernet, and Ive been asked to connect an additional...
5,368
I am having a problem with the max value when using a numeric input on the PVP 600. I created the numeric input and I am able to change the value...
4,013
Hello, I made a small change to my FTV ME file (added an ack-all button) and re-downloaded to my PVP. Since then, when the application starts up...
1,031
Hello everyone, I'm seeing Japanese characters with a 90° rotation on a new PVP+7 screen. I post here hoping someone has encountered this issue...
761
