PVP1500 and ML1500 Remote Display Control
3guest
Dec 2006
Kitchener
Does anyone know if it is possible to detect communication error (lost of communication) between PVP1500 and PLC and how to show that in the form of some indicator?
In case of lost of communication between PVP1500 and PLC, is it possible to turn off remote display control (actually to set remote display number to 0)?
Any help will be appreciated.
On the first question, yes: There's a pre-defined Item for each Device Shortcut in RSLinx Enterprise called "@IsPresent" that reflects the connection status to a controller. I use it to put a "don't panic, it's just unplugged" indicator onscreen.
I'm not sure about handling remote display control, though. Maybe another member who has done it can chime in.
Hi all, PLC : Micrologix 1500 lrp HMI : Renu FP3070 TN I am a beginner in the plc world. I am trying to connect the renu hmi with ML1500 lrp in...
771
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,365
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,236
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,217
Hello, I have the PLX setup and configured. Its seen and downloaded to. However my ML1500 does not communicate over it. The port (0) is used...
1,665
