PVplus error message "ID=4098"
ogimoj
Dec 2003
22
I'm getting an error message in the diagnostic of my panelview plus 1500 that says only: "ID=4098"
I've been unable to find any documentation that might give me a hint as to what this means.
My panelview is communicating to a PLC5 via devicenet. The main issue I'm having is with PV outputs (PLC inputs) not working consistently. The PV is set up as a slave on devicenet, and the PLC-5 scanner and the PV are the only two nodes on the network (channel 2 of the scanner - channel 1 has other nodes). The status word of the scanner indicates that communications are fine. The BTR is not giving me an error. Diagnostics on devicenet indicate that all is well. Outputs from the PLC to the panelview seem to be working fine (indicators change state, etc.)
When I boot the panelview, the screen number will (that I have configured in global connections) shows up in the PLC data file at first, but after some time (anywher from 15 seconds to several minutes), all values in the PLC data table go to zero, and I start getting the message "unable to write value "[x]" to [whatever hmi tag or devicenet alias]".
Any ideas?
Hello Everyone, I have created project in FTview 8.0 (ME edition). Now trying to transfer application to HMI PvPlus Compact 600. But when...
2,980
Hi. We have a PvPlus1000 that is showing the following error code: (LegacyDP0x002047D0) Timed out reading from block 0x00222E88 Can't seem to...
1,668
Hi Guys, I have a PVPlus 700 installed on an equipment from which I would like to print a selected screen when I hit the print button on the PV...
4,880
Hello, I want to make touchscreen push buttons invisible based on certain conditions. When these conditions are true, these buttons will become...
999
So I've got an issue I have yet to figure out. I have a PVPlus standard HMI runtime v12. I've gone into the system and set the date and time and...
4,881
