PVPlus to second monitor
Udunit
Mar 2014
Woodstock, Ontario
33
I'm looking to use a second monitor as a data display for a customer. I know the FTVP is available but would like to actually duplicate the screens on a second monitor (basically mirroring what is on the PV on a second display). It's not a large application so I can work it this way. Anyone do this outside of Factory Talk Viewpoint?
Yeah just use the VNC server that's built into the newer ones. I used viewpoint for awhile on a couple projects and i wasn't very happy with it so i started using VNC server on them and its a lot better.
If you do this they will have access to everything you can do from the PV unless you set it up to be view only then they cant do anything but view. Link is below.
https://theautomationblog.com/remotely-controlling-your-a-b-pvplus-using-vnc/
Hello, I want to make touchscreen push buttons invisible based on certain conditions. When these conditions are true, these buttons will become...
1,007
So I've got an issue I have yet to figure out. I have a PVPlus standard HMI runtime v12. I've gone into the system and set the date and time and...
4,938
Hello all. Sure hope someone can help with this. I have a system down because it is dependent upon its PV1000 and operator inputs to run it. I had...
1,613
On all of my PVplus 700's; once the download is complete, the HMI restarts with the new .MER file. On my 600, I have to exit to configuration and...
1,529
I can't create a shortcut in RSLinx Enterprise for the Micro850 simulator. I can see in the network but when I select it, the Apply button turns...
1,249
