thingstodo
There's nothing to it...
1. Feed it the 0-100% CV from the PID
2. Set the cycle time
3. Set the min/max time
4. Set the min/max percent, typically 50/100%
Don't make this harder than it should be. Unless you just really want to.
+1 on that.
My advice is to start as simple as you can, and work from there. You have several suggestions on this thread.
I have had grand plans in the past .. that get flushed down the drain after the first field test when things are not-quite-as-the-customer described ...
It's an iterative process. Document your assumptions. Document how the situation changes - measurements, equipment, staffing - and document what you tried, what worked and what did not.
You won't remember any of these details 6 months after it works. Make it easier on yourself later .. on on the next guy after you move on.
