Quantum 140NOE771-11 IP problems
Radders
Sep 2006
Essex
I have a problem with a Quantum 434 PLc that when the power is interupted, and then regained, the NOE711-11 loses its IP and assumes a new IP already used on the subnet. There is no DHCP server and all IP's are static. The Schneider FDR is not configured on any of the NOE cards and the IP is set via the Configuration Extension on the PLC.
This is one PLC on a network on 40, which allows fails to the same IP address each time there is a significant power loss, thus causing the NOE to go offline due to the IP address already being used. Has anyone experienced this???
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
90
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
312
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
669
Hey guys. Mostly new to this stuff so I apologize if I'm not following proper format. I have 3 working CPU133 /3s. There is a desktop with a...
913
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
506
