Queries
vijayeie
Sep 2006
Any one can you please help.....
1) What is the difference between Automation Engineer & PLC Engineer. What's the scope between these two?
2) What is the difference between HMI & SCADA?
3) What is the difference between PLC & DCS?
PLCs are used in automation. Automation is a lot more than PLCs alone, you can also have relay logic, electronic control cards, drives etc. Apply this to the engineer and you'll see that an automation engineer has to learn a lot more than only PLC. A PLC engineer on the other hand should have a far greater knowledge on PLC than an automation engineer.
HMI is Human Machine Interface. SCADA is Supervisory Control and Data Acquisition. In other words: HMI is limited to just interfacing, SCADA can be a lot more.
PLC: Programmable Logic Control, DCS: Distributed Control System. Doesn't the terminology say it all?
Kind regards,
I read that using rack optimization a single CIP connection will be used to transfer IO data from remote card to local card, provided its a...
1,972
Hello, I have a data grid view component in VS2013 displaying data from MySQL using advanced hmi 3.99w. The first question; is it possible to...
1,749
Hi everyone, I'm working in automation department, I have some questions regarding the Ethernet Connection. Is multiple switches can reduce the...
1,910
Hi, We have a few projects where animation based on historical data would be a real nice feature. Can this be done with Ignition?
3,404
Hi, I have configured the Anybus Profibus-Serial Gateway to interface my serial RS 232 based device to a PROFIBUS-DP network. The gateway...
8,081
