Question abotu GE fanuc plc programming.
briana banks
Jul 2005
242
Hi All
Using GE RX3
I would like to create a function block that recive UDT (uder defined data type) manipulate it and return it after changes.
something that works like C language function i.e. parameters and arguments.
Thanx
Do a search in the Proficy MAchine Edition Help files for UDFB. This is a User Defined Function Block, I think it is what you're looking for.
Also read the section on using timers and counters in UDFB's when multiple instances of the UDFB will be used. There are some caveats with certain timer and counter types.
Hope this helps!
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
175
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
94
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
100
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
