Question about Beckhoff servo drive Ax5201
mhismail
Mar 2016
egypt
30
Hi guys ,
I have beckhoff servo drive ax5201 & servo motor am8012 .
i am using twincat 3 . I scanned the devises and everything is connected to my pc very well but i have one problem i will summarize it as follows :
(1) In twincat : i can see the drive and the motor in "I/o devices" so there is no problem in reading the devices.
(2) I have a permanent error "fd10" which is defined in the diagnostic manual as "peripheral voltage too high" ,now here is the data :
Ax5201 : supply voltage from 100 to 480 (3 phase)
motor am8012 : supply voltage is 230 volt (3 phase)
i can guess the problem to be in one of two places :
(a) In Twincat when i configure the motor it requires the power setting so which setting should i use , the 230 volt of the motor OR the 480 of the drive ?? btw , i connected the drive to 380 volt ac and choosed the power setting of the motor (230 volt ) ...may be this is why i get the error !!
(b) In hardware wiring , should i supply the servo drive with 380 which is within the range of the datasheet or should i supply it with the motor voltage which is 230 ?? btw , if i would use induction motor , the drive (inverter) would be supplied with 380 volt and yet will supply the motor with it needs which is 230 volt , Do servo drives acts like inverters in this problem ?
Thank you in advance
Hello all. I have been tasked with working on a Beckhoff iPC (C6640-0020) and have never even seen one, until now. I went on their website to find...
474
I did a Beckhoff TwinCAT3 motion training course a couple of months ago. To be honest, it was a little tough going as it was my first sight of...
3,045
I have several Beckhoff Remote I/O's connected to an Siemens S5 PLC. My question is if I lose comms to the Remote I/O, do the remote outputs stay...
1,894
Hi all, I am wondering if there is a way to graphically display all configured network connections and devices in TwinCAT PLC? Something...
1,440
I'm pretty new to programming using beckhoff software so please bare with me. I am programming a linear transfer line and to help simplify the...
4,602
