Question about calling FC's in S7
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all
I've translated an S5 program into S7 but unfortunately it doesn't work.
I've even used the S5 converter to check my conversion and it seems fine.
Within the S5 there are several calls to the same block, FC 83, which is a S5-S7 Block 16bit Multiplier.
My question is this...
Could it cause a problem calling this block several times from within the one block and sending different parameters to it?
Or is it perfectly acceptable to call these blocks as many times as you want and just send different values each time??
If it was an FB I would put different Instance DB's with every call but with it being an FC I don't have that option...
Can anyone clarify this for me
Many thanks in advance
An FC can be called as many times as you want, one after the other if you want.
The rules with an FC, internally is simply, if the parameter is an IN, then do not write to it in the block, if its an OUT, then ensure that you condition it in the block prior to using it.
If you need to update an IN or remember an OUT, then it has to be IN_OUT.
Providing the above is adhered to you should be fine.
Regarding the data passed in and out, ensure the same addresses are not being used which can cause errors.
Can you be more specific about what is not working ?
(e.g. I've just built a nuclear power station and it's not working - can anyone help) :)
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
18
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
182
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
130
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
101
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
112
