Question about high speed counter Quantum
yolandin
Oct 2012
Chicoutimi, Montréal
Hello everyone,
I am currently using a high speed counter card on Quantum 140EHC10500. I was wondering how the works counting inputs. I'm using an encoder 24vdc, connected to terminals 11-12, 13-14, etc. Are the inputs 5 Vdc (1-12, 2-14, etc.) use the same registers as inputs 24 VDC? Is there a configuration to do in the card configuration? I'm programming with unity pro v4.1
Thank you.
hi, im using cj1m cpu22 and I plan to use the built in high speed counter to count the pulses from a rotary encoder. We are measuring the rpm of a...
5,134
M
i'm using PLC to drive up a servo stepping motor with 2 phase encoder. what should i do to obtain the counting value, and how to use the value to...
3,206
Makinen
M
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
80
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
193
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
182
