Hi! With this it isn't work... L PIW20
T MW20
I don't know what the problem is??!!!
Here is my hardware configuration:
FILEVERSION "3.2"
#STEP7_VERSION V5.4
#CREATED "20. septembar 2007 8:23:56"
STATION S7300 , "SIMATIC 300(1)"
BEGIN
REPORT_SYSTEM_ERRORS "0"
_ATTR2_111755 "1"
OBJECT_REMOVEABLE "1"
POS_X "0"
POS_Y "0"
SIZE_X "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
END
SUBNET MPI , "MPI(1)"
BEGIN
MPI_HSA "31"
MPI_BAUDRATE "187.5_KBPS"
MPI_GAP "5"
MPI_READY "20"
MPI_RETRIES "2"
MPI_IDLE1 "60"
MPI_IDLE2 "400"
MPI_TQUI "0"
MPI_TSL "415"
MPI_TTR "9984"
CREATOR ""
COMMENT ""
NET_ID_2 "00 1B 00 00 00 06"
NET_ID "001B00000006"
END
RACK 0, "6ES7 390-1???0-0AA0", "UR"
BEGIN
POS_X "236"
POS_Y "17"
SIZE_X "603"
SIZE_Y "344"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
END
RACK 0, SLOT 1, "6ES7 307-1EA00-0AA0", "PS 307 5A"
BEGIN
CPU_NO "1"
ALARM_OB_NO "40"
POS_X "0"
POS_Y "0"
SIZE_X "0"
MODULE_ADD_FLAGS "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
END
RACK 0, SLOT 2, "6ES7 315-2AG10-0AB0" "V2.0", "CPU 315-2 DP"
BEGIN
ALARM_OB_NO "40"
CBA_USAGE "0"
CAPABLE_FAILSAFE "0"
POS_X "0"
POS_Y "0"
SIZE_X "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
MPI_ADDRESS "2"
COMMENT ""
LINKED_SUBNETNAME "MPI(1)"
END
RACK 0, SLOT 2, SUBSLOT 1, "_S7H_SUBMODULE_315_2AG10_DP_CT", "DP"
AUTOCREATED
BEGIN
PROFIBUSADDRESS "3"
ALARM_OB_NO "40"
DP_CLOCK_MODE "0"
SLAVE_ACTIVE_PASSIVE "0"
DP_CLOCK_INT "0"
_ATTR2_111748 "0"
DP_MASTER_MODE "DP_MASTER"
OBJECT_REMOVEABLE "0"
POS_X "0"
POS_Y "0"
SIZE_X "0"
SIZE_Y "0"
DP_VERSION "7"
CAX_APP_ID ""
L2_ADDR_EQUI_MASTER "255"
OBJECT_COPYABLE "0"
CREATOR ""
COMMENT ""
LOCAL_IN_ADDRESSES
ADDRESS 2047, 0, 0, 0, 7, 0
END
RACK 0, SLOT 4, "6ES7 321-1BL00-0AA0", "DI32xDC24V"
BEGIN
CPU_NO "1"
ALARM_OB_NO "40"
POS_X "0"
POS_Y "0"
REDUNDANCY
BEGIN
END
SIZE_X "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
LOCAL_IN_ADDRESSES
ADDRESS 0, 0, 4, 0, 1, 0
SYMBOL I , 0, "P22-D", "Pumpa rekuperatora HZP - P22 (daljinski rad)"
SYMBOL I , 1, "P22-B1", "Pumpa rekuperatora HZP - P22 (u radu)"
SYMBOL I , 2, "P22-B3", "Pumpa rekuperatora HZP - P22 (prorada zastite)"
SYMBOL I , 3, "P13-D", "Pumpa grejaca - P13 (daljinski rad)"
SYMBOL I , 4, "P13-B1", "Pumpa grejaca - P13 (u radu)"
SYMBOL I , 5, "P13-B3", "Pumpa grejaca - P13 (prorada zastite)"
SYMBOL I , 6, "KH-PV-D", "Usisni ventilator HZP (daljnski rad)"
SYMBOL I , 7, "KH-PV-B1", "Usisni ventilator HZP (u radu)"
SYMBOL I , 8, "KH-PV-B3", "Usisni ventilator HZP (prorada zastite)"
SYMBOL I , 9, "KH-OV-D", "Otsisni ventilator HZP (daljinski rad)"
SYMBOL I , 10, "KH-OV-B1", "Otsisni ventilator HZP (u radu)"
SYMBOL I , 11, "KH-OV-B3", "Otsisni ventilator HZP (prorada zastite)"
SYMBOL I , 12, "P16-D", "Pumpa P16 (u lokalu)"
SYMBOL I , 13, "P16-B1", "Pumpa P16 (u radu)"
SYMBOL I , 14, "P16-B3", "Pumpa P16 (prorada zastite)"
SYMBOL I , 15, "P19-D", "Pumpa P19 (u lokalu)"
SYMBOL I , 16, "P19-B1", "Pumpa P19 (daljinski rad)"
SYMBOL I , 17, "P19-B3", "Pumpa P19 (u radu)"
SYMBOL I , 18, "KH-ZU-B1", "Reg. zaluzina na usisu HZP (otvorena)"
SYMBOL I , 19, "KH-ZU-B2", "Reg. zaluzina na usisu HZP (zatvorena)"
SYMBOL I , 20, "KH-ZO-B1", "Reg. zaluzina na otsisu HZP (otvorena)"
SYMBOL I , 21, "KH-ZO-B2", "Reg. zaluzina na otsisu HZP (zatvorena)"
SYMBOL I , 22, "KH-MR", "HZP (mraz termostat)"
SYMBOL I , 23, "KH-PU", "HZP (presostat ventilatora na usisu)"
SYMBOL I , 24, "KH-PO", "HZP (presostat ventilatora na otsisu)"
SYMBOL I , 25, "KH-PF1", "HZP (dif. presostat ventilatora na usisu)"
SYMBOL I , 26, "KH-PF2", "HZP (dif. presostat ventilatora na otsisu)"
SYMBOL I , 27, "KH-PPK1-B1", "Protivpozarna klapna KH-PPK1 (otvorena)"
SYMBOL I , 28, "KH-PPK1-B2", "Protivpozarna klapna KH-PPK1 (zatvorena)"
SYMBOL I , 29, "KH-PPK2-B1", "Protivpozarna klapna KH-PPK2 (otvorena)"
SYMBOL I , 30, "KH-PPK2-B2", "Protivpozarna klapna KH-PPK2 (zatvorena)"
END
RACK 0, SLOT 5, "6ES7 331-7KF02-0AB0", "AI8x12Bit"
BEGIN
CPU_NO "1"
ALARM_OB_NO "40"
POS_X "0"
POS_Y "0"
REDUNDANCY
BEGIN
END
SIZE_X "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
LOCAL_IN_ADDRESSES
ADDRESS 20, 0, 16, 0, 1, 0
PARAMETER
GROUP_DIAGNOSIS, AI , 0, "1"
GROUP_DIAGNOSIS, AI , 1, "1"
GROUP_DIAGNOSIS, AI , 2, "1"
GROUP_DIAGNOSIS, AI , 3, "1"
WIRE_BREAK, AI , 0, "0"
WIRE_BREAK, AI , 1, "0"
WIRE_BREAK, AI , 2, "0"
WIRE_BREAK, AI , 3, "0"
LIMIT_VIOLATION, "0"
DIAGNOSTICS, "0"
INTEGRATION_TIME, AI , 0, "20_MS"
INTEGRATION_TIME, AI , 1, "20_MS"
INTEGRATION_TIME, AI , 2, "20_MS"
INTEGRATION_TIME, AI , 3, "20_MS"
AI_TYPE, AI , 0, "CURRENT_(2-WIRE_TRANSDUCER)"
AI_TYPE, AI , 1, "CURRENT_(2-WIRE_TRANSDUCER)"
AI_TYPE, AI , 2, "CURRENT_(2-WIRE_TRANSDUCER)"
AI_TYPE, AI , 3, "CURRENT_(2-WIRE_TRANSDUCER)"
AI_RANGE, AI , 0, "4_TO_20_MA"
AI_RANGE, AI , 1, "4_TO_20_MA"
AI_RANGE, AI , 2, "4_TO_20_MA"
AI_RANGE, AI , 3, "4_TO_20_MA"
UPPER_LIMIT_VALUE, AI , 0, "22.962384259260"
UPPER_LIMIT_VALUE, AI , 1, "22.962384259260"
LOWER_LIMIT_VALUE, AI , 0, "-14.962962962963"
LOWER_LIMIT_VALUE, AI , 1, "-14.962962962963"
END
RACK 0, SLOT 6, "6ES7 322-1BL00-0AA0", "DO32xDC24V/0.5A"
BEGIN
CPU_NO "1"
ALARM_OB_NO "40"
POS_X "0"
POS_Y "0"
REDUNDANCY
BEGIN
END
SIZE_X "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
LOCAL_OUT_ADDRESSES
SYMBOL O , 0, "P22-C", "Pumpa - P22 (HZP) (ukljucenje/iskljucenje)"
SYMBOL O , 1, "P13-C", "Pumpa - P13 (HZP) (ukljucenje/iskljucenje)"
SYMBOL O , 2, "KH-PV-C", "Usisni ventilator (HZP) (ukljucenje/iskljucenje)"
SYMBOL O , 3, "KH-OV-C", "Otsisni ventilato (HZP) (ukljucenje/iskljucenje)"
SYMBOL O , 4, "P23-C", "Pumpa - P23 (HZM) (ukljucenje/iskljucenje)"
SYMBOL O , 5, "P14-C", "Pumpa -P14 (HZM) (ukljucenje/iskljucenje)"
SYMBOL O , 6, "KM-PV-C", "Usisni ventilator (HZM) (ukljucenje/iskljucenje)"
SYMBOL O , 7, "KM-OV-C", "Otsisni ventilator (HZM) (ukljucenje/iskljucenje)"
SYMBOL O , 8, "P24-C", "Pumpa - P24 (GAR) (ukljucenje/iskljucenje)"
SYMBOL O , 9, "P15-C", "Pumpa - P15 (GAR) (ukljucenje/iskljucenje)"
SYMBOL O , 10, "KG-PV-C", "Usisni ventilator (GAR) (ukljucenje/iskljucenje)"
SYMBOL O , 11, "KG-OV-C", "Otsisni ventilator (GAR) (ukljucenje/iskljucenje)"
END
RACK 0, SLOT 7, "6ES7 332-5HF00-0AB0", "AO8x12Bit"
BEGIN
CPU_NO "1"
ALARM_OB_NO "40"
POS_X "0"
POS_Y "0"
REDUNDANCY
BEGIN
END
SIZE_X "0"
SIZE_Y "0"
CAX_APP_ID ""
OBJECT_COPYABLE "1"
CREATOR ""
COMMENT ""
LOCAL_OUT_ADDRESSES
ADDRESS 4, 0, 16, 0, 1, 0
PARAMETER
GROUP_DIAGNOSIS, AO , 0, "1"
GROUP_DIAGNOSIS, AO , 1, "1"
GROUP_DIAGNOSIS, AO , 2, "1"
GROUP_DIAGNOSIS, AO , 3, "1"
GROUP_DIAGNOSIS, AO , 4, "0"
GROUP_DIAGNOSIS, AO , 5, "0"
GROUP_DIAGNOSIS, AO , 6, "0"
GROUP_DIAGNOSIS, AO , 7, "0"
DIAGNOSTICS, "0"
REACTION_TO_CPU_STOP, AO , 0, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 1, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 2, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 3, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 4, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 5, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 6, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
REACTION_TO_CPU_STOP, AO , 7, "OUTPUTS_WITHOUT_VOLTAGE_OR_CURRENT"
AO_TYPE, AO , 0, "CURRENT"
AO_TYPE, AO , 1, "DEACTIVATED"
AO_TYPE, AO , 2, "DEACTIVATED"
AO_TYPE, AO , 3, "DEACTIVATED"
AO_TYPE, AO , 4, "VOLTAGE"
AO_TYPE, AO , 5, "VOLTAGE"
AO_TYPE, AO , 6, "VOLTAGE"
AO_TYPE, AO , 7, "VOLTAGE"
AO_RANGE, AO , 0, "4_TO_20_MA"
AO_RANGE, AO , 1, "ZERO_VALUE"
AO_RANGE, AO , 2, "ZERO_VALUE"
AO_RANGE, AO , 3, "ZERO_VALUE"
AO_RANGE, AO , 4, "+/-_10_V"
AO_RANGE, AO , 5, "+/-_10_V"
AO_RANGE, AO , 6, "+/-_10_V"
AO_RANGE, AO , 7, "+/-_10_V"
END
