Keldog
Hey all. I was wondering at the sawmill where i do some PLC programming they have a bull edger.
There is an outfeed sensor, and what they want is when the outfeed sensor is clear the blades to go back to a certain position and a timer to start for 5 seconds.
When the outfeed sensor is tripped a timer starts for a different application, what i was wondering if there is a way so that when it clears that the blades go to a certain position and the timer to start.
Is there a way i can set a bit so it only reads after the sensor is cleared i was thinking a ONS but i can't seem to get it to run properly it just sticks on.
I was just wondering if there was a way.... thanks in advance
If there is any questions and you use msn you can add me at [email protected] it would be easier to explain to you.
