Quick Question About Siemens Smart Relay
jivey1026
Sep 2008
Clanton, AL
Hey guys got a quick question. We have some smart relays laying around from out of date fixtures and I have used them in the past, siemens and idec. The question I have is the ones that I used before were relay outputs. Then one I have now is Transistor/.03A output. Can someone explain transistor output to me please.
Thanks in advance
I find it hard to put in words hehe.
The relay is simply a relay activated by the conditions you set.
A transistor output is suplied from within and can suply a load of 0.03A (0.3A?).
Yes I understand what a relay output is and how it works. I guess what I don't understand is what you mean by a transistor output is supplied within. The relay has "Q1" and "M" for each of its four outputs. I'm not sure how to wire this up because "M" at the top where the supply voltage to the smart relay is, is for 24 VDC Common. Would that make this a "Sinking" output where it switched the 24VDC common?
the 505 series. which direction does the scan start from... top or bottom? I seem to remember either the siemens or maybe modicon stating the scan...
1,911
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,299
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
913
Has anyone come across a 3 turn potentiometer that is panal mounted with either a 22 or 30 mm hole? I have been looking but nothing so far. They...
20
4,780
Hi, I am just learning CCW, finally got connected to a micro820. I'm wondering what the Version number means. The program that was already in the...
1,638
