Quickpanel HMI
Elec
Dec 2023
Batam
Dear colleagues, hello to everybody!
I have a problem with Quickpanel IC754VBI06SFD-GF
Proficy Machine Edition Runtime 6.5
QuickPanel View V2.00
Windows CE. NET v5.00
I used PME6.0 and 7.0 with same effect: "there was problem copying the temporary project. Consequently the temporary project can not be opened"
Any ideas what can be wrong from my side?
I'm newbie with PME, but IP is the proper one, ping is passing.
Thank you in advance
Hi there, I am not familiar with this product. But since it is Sunday afternoon here in Asia, it may be some time before others read your post, so I try to help by suggesting that you make sure you are starting this software with Windows administrator rights (elevated mode). Some Windowds application do not copy required files when using the computer with normal user credentials. Good luck!
Thanks for reply
I'm trying to upload configuration. Type of new opened project is matching to HMI 100%
It could be that the project in the Quick Panel was created with a newer version of Proficy than you're using. It could be that the person who downloaded the project to the QP only downloaded the runtime and did not include the full set of files.
I need to try to get an upload from a GE Quickpanel View HMI, IC754VSI06STD-KH, model: ES0611. I saw the thread...
2,781
Hi there to all! I am making some testings trying to read the values from an HMI Quickpanel +, in this HMI i'm writing a value into a float...
1,668
Looking to find a programming cable to download an already developed Quick Panel application which I have the software for. The hardware is a...
5,067
All, I have an old 10.4" QuickPanel that came off of a SIMPLIMATIC can palletizer. The HMI does not have the program in it and the company is no...
1,622
I have a file from a quickpanel 2 that I need converted to work with a pro-face HMI. It is a .prj file. It looks like it needs to be converted...
1,633
