Raw TCP/IP connection to Red Lion
Feb 2012
Paris
Anyone have any experience in connecting RL G3 or CSMSTRLE in order to access, on a raw TCP/IP level, internal words comming from a PLC?
I suppose that with the param "Raw TCP/IP passive" (found under <System>) RL acts as a TCP listener waiting for a TCP client's request for connection. That works between 2 PCs, but when my TCP client program try to connect RL configured with "Raw TCP/IP passive" default address and port (192.168.1.20:1234) I get the Socket Exception with the message : "No connection could be made because the target machine actively refused it "
Any info or suggestion would be much appreciated.
Hello Philippe,
I am new to RedLion and working with Raw TCP/IP port. Have now idea where to start. Can you please update your thread how did you make the raw TCP/ip port working? My Red Lion will receive data from a PC through TCP/IP and send data to another unit through serial port. They both are raw types.
I would appreciate your kind help very much.
Hello Philippe,
This is based on a previous project and I don't guarantee that it is the only or the best way to do this...
To receive data you would use the Raw TCP/IP Passive Driver and to send data you would use Raw TCP/IP Active.
Assuming you have the IP Address etc set up on the Active port you would write a program that uses PortPrint() to send data when you want it sent to the "slave" device Of course, the message needs to be in a format that the slave understands.
As to Receiving Data, you need to write a program that is called in the On Update event of the Passive Driver port. This program will parse the incoming data into a usable format for your application.
This works just the same using the Raw Serial Driver except the Mode is either Slave (like Passive above) and Master (like Active above)
I hope this gets you pointed in the right direction.
Hi, I have a Siemens PLC which is connected to a Siemens RMC30, they were functioning fine communicating via Modbus TCP/IP but have now stopped...
1,819
Hello All, I am a newbie of PLC and Red Lion. I am working on a project which has RedLion HMI which receives data through TCP/IP from a...
2,534
Dear, My problem is how to read special variables (pressure, temperature, ...) from tcp raw data stream generated each 100 milliseconds and use...
2,500
Dear, I have a webserver 192.168.0.5:111, where it have data. How can I read those data on S7-1200?
1,979
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
72
