Re-size PVComponent Application
Marc
Jun 2004
Nashua, NH
430
Hi all,
I have a .CHA file that was written for a 6 Inch monochrome Panel View Component. I am trying to load it into a 4 Inch color PV Component screen and it looks fine, just gives an error on every re-boot.
Have any of you successfully done this? Can't seem to find a way to change the type of device the .CHA file is tied to.
THX!
Marc
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
226
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
103
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
128
Supposing I want to be put a TIA Portal Project "executable image" onto a memory card (e.g. see picture). The reason for doing this is so that I...
392
Hi all, I am having an issue with FT View Studio ME when I try to open the propoerties of any object, the size of it is very big and doesn't let...
111
