Read HZ feedback from powerflex 4
poisonfrog
Jan 2005
34
I have a problem in which operators want to view the HZ of a drive that is locked in a cabinet. I want to displaz the HZ on a panelview that is hooked up to the machine. I have a powerflex 4 drive, a panelview 600, and a PLC 5/15. I read that the drive is capable of modbus functions that would accomplish this. We use DH+... Is there a way I can get this done, and if not is there another easy way to display the HZ besides putting a piece of plexi in the cabinet?
How is the drive speed being controlled ?
It's not easy or cheap to get a Modbus RTU master implemented on a PLC-5/15 controller. If the PLC is commanding the drive via an analog output, it might be best to display that output value scaled to match the resulting Hz output.
The drive speed is not being controlled by the plc... We just set the knob for the HZ we need. We only send start/stop signals to it.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
193
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
147
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
283
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
119
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
166
