Read I/O via Modbus TCP
Guest
Guest
G
Hi!
Could any body show me Modbus frame to read output(s) for reference!
(complete frame or only addressing section)
Example: Read %Q103.5 from first rack, PLC Telemecaniqe TSX 57 473
Thanks in advance
first of all what is your requirement with modbus adressing with Telemecaniqe TSX 57 473(??), becoz. it by default support unitelway.
Whatsoever try installing modbus comm. driver then connect your plc to the application software through modbus. remember to intialize modbus in the communication port of your programming terminal. then you might read any output status through the application software.
regards,
LadderLogic said:
That's interesting... I did not know that Modbus protocol even allows to access the physical outputs memory.
I think it depends on the controller. It's really up the the manufacturer to decide where address 00000, 30000, etc. is in memory.
I have Micro850 with module 2080-Serialisol. It is needed to read 5 registers from a device via Modbus RTU. The device is Ok, I can read the data...
1,147
Dear all, glad to be here and I hope that we all can benefit from this great community. I am trying to send and receive data between two Mico850...
2,776
Dear all I want to make S7-1200 as Modbus RTU gateway (Master and slave all in one) I have bought : 1 x 1214C CPU 2 x CM1241 RS422/485 The fisrt...
4,080
I have a twido TWDLCAE40DRF PLC, IP 192.168.0.1, connect to a network switch port 1. Also, I have a modbus Power Meter (Device ID: 5, PLC try to...
8,963
