Reading analog ouput from a PLC- 0to 10V
duskndreamz
Apr 2010
Delhi
I have connected a sensor which gives 0 to 10V to a DVP 20EX PLC's analog input.
According to the manual of the PLC, its ch0 analog input is at register D1156.
But on observing the register, it is not showing any value.
The connections seem fine as the voltage difference between the two analog input terminals (v+ and v-) is between 0-10v.
Do we need to modify something, or program the PLC somehow to get this data correctly??
I am setting up a new system and have an s7 1214 plc with an sm1231 4x AI (6ES71231-4HD32-0XB0). It is configured for 0-10v and has no faults in...
1,159
I'm pretty new to Siemens. I just downloaded a new program into a new S7-1500 CPU. All modules are ok/not faulted. here is the problem: i have 4...
2,929
I just added a 1746-NI4 in remote rack slot 9 and ch0 is set to 0-10V input. Now I am trying to read the AI and the value getting back from BTR is...
2,260
I need some help. I have a 1769-IF4 analog card that is hooked up to strain gages, the gages give a 4-20ma signal to the card. We had an...
2,040
Hi all! Is someone can help me to understand what they means ? This is the only info I could find on my device : With this module is possile to...
2,354
