Reading scantime S7
RemcoK
Feb 2005
Brasil
Does anybody know how too read the scantime from a Siemens S7. I need too make an very fast timer and want too read the scantime for this.
I Mitsubishi it's very easy, but I don't know where I can find this in Siemens S7.
Tanks
Remco
Simple.
In OB1, load the local data #OB1_PREV_CYCLE and transfer it to an address for further processing (Merkerword or Dataword as an INT).
The value is the cycle time in milliseconds.
Scan time alternative
For creating youre own timer, you could also use SFC 64.
It is like a rolling counter (0-2147483647 then start again at 0) that counts in mili seconds.
168
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
92
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
245
Dear all, I don't know why setup of password became challenging and weird. After setting up the password and try to upload the ladder from the plc...
178
