Reading switch statuses using an Ethernet Base Controller
BretB
Mar 2007
Clearwater, Florida
Hi everyone,
I just got a new Ethernet Base Controller, with two 16 input modules, in a 4 slot base (normally known as a PLC) with a 24V DC power supply.
I managed to get it all set up with power, hooked up from the power supply to a switch, then to the input modules, and I can flip the switch and watch the lights on the input modules turn on and off - a milestone!
I even managed to assign the thing an ethernet address and I plugged it in to my computer with a serial cable and the DirectSoft program recognizes it for what it is - an EBC. I can also ping it through its IP address through the ethernet cable.
Now - what I need to accomplish is reading the status of the 32 input "switches" - I need to know if each of them are ON or OFF - open or closed.
How do I go about this the smartest? Keep in mind that there is no CPU here as I don't need any processing. I just need the statuses of each of these switches fed into my computer. And I don't want to depend on a propritary Win32 program if I can help it as I need these PLCs to be able to be set up on many different computer systems and I don't want to have to go around setting up this program on each of those PCs.
Any help will be much appreciated.
- Bret B
You can either buy the KEPDirect OPC Server from AutomationDirect or you can create your own interface. Host Engineering offers a Ethernet Software Development Kit for the EBC for free. It is also possible in some cases to get the source code and I see that they have some customer created ports for Linux and Solaris.
http://www.hosteng.com/
I believe the EBC100's have Modbus/TCP as well. That is another alternative. You can roll your own with modbus or buy a component.
Or, do what Tark says.
Is there a way to interface a keypad using switch matrix circuitry to plc inputs, specifically an AB 1746-IB16 24vdc (<5v=off, >10v=on)input...
8,837
205
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
147
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
121
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
263
