Reading Sy/Max logic
argaul
Jul 2014
Dallas
Hey everyone.
I am trying to translate an old Square D Sy/Max 300D ladder program to Unitronics' Visilogic. However there are notes so I have no clue what any of the bits are; internal, inputs, outputs, timer contact, ect.
From skimming through the program there appear to only be NO, NC, coils and timers in the program.
If anyone know a source for how to read Sy/Max bit references and timers it would be greatly appreciated. I have attached a rung from the code.
if you have the original program using 'ALT L' will show you the labels.
the Sqd program uses registers it was a very powerful PLC in its time.
Thanks Ian,
Unfortunately I only have PDF's. I'll see if the customer has access and able to do that though.
The labels are not kept on the processor
so only an original copy of the program on disk might have them.
it was easy to loose the data so don't try too hard
I'm trying to read a table of 100 floats over ethernet from a ML1400 to an L61 CLX. I find I can only read 58 elements at a time before the MSG...
2,530
176
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
98
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
251
