Real VNC launched form RSView32
krakenfan69
Nov 2011
Alberta
229
Hi guys,
I have an RSView 32 project that I want to add a button to launch Real VNC and remote into a Panelview. I added the Panelviewer IP address to Real VNC and the linkage to launch Real VNC. My question is, how do I set it to launch a particular server? There are 3 in the drop down menu. I know I need to make a registry change to bring the application to the front. Just not sure how to activate the proper VNC connection.
Thanks,
Kraken Fan #69
I set my RSView button with this.
AppStart "C:\Program Files\RealVNC\vncviewer.exe" "C:\Users\albops\AppData\Roaming\RealVNC\VNC Address Book\15-15-15-15.vnc"
This launches RealVNC and then the saved shortcut 15-15-15-15.vnc
You will likely need to edit the Registry to make the Client open in the front of RSView rather than behind it Instructions for that are located in this TechNote.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/9041
Hope this helps someone.
Kraken Fan #69
It's rare to have someone come back and answer their own question for the benefit of future searches. Thank you for that!
I'm stumped by something seemingly simple. I want to move the numerical value of an ASCII style SINT into a REAL tag in Studio 5000. What's the...
64
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
147
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
146
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
220
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
124
