Recipe vieuw in WInCC Flex, no reals ???
userxyz
May 2002
any
2,768
I use the recipe vieuw in WinCC Flex to enter some parameters.
I have some real parameters.
But, when I enter 7,5 for example, then it makes an 8 of it...
Any ideas how to be able to enter reals ?
Sounds like you don't have the number format set. 99.999
edit: Sorry you don't set it with 99.999 but you must tell it how many decimal places when you add the tag to the recipe.
I tought this was for DINT
But you can be right, I'll check it out
thanks
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
79
I'm using legacy recipe to download a recipe to the PLC. A little background, the recipes are large. They are broken down into 6 tables, each 16...
125
Hi guys, got one problem PLC model fp-xh c60t and HMI model TG765S-MT I've encountered an issue which is the recipe file went missing if i swtich...
89
Can anyone help me find where is recipe plus or recipe manager in View desginer(studio 5000) software. i want to create an recipe but i am unable...
189
Need to add new tags to some recipe inside a Wincc Tia Hmi . Do we have an option to download the recipe , with the newly added elements ...
246
