Recipes in AD 06 and C-More
piscis
May 2003
241
I would like to know how you guys handle projects that call for storing recipes inside the PLC.
I need to allow the operator to create up to 100 different recipes with 5 ingredients on each one using only the small C-More touch screen panel.
My customer needs a solution that does not required logging into the PLC or the Panel and making any changes to the logic.
I will like love to hear your suggestions, how would you approach this?
Thanks all!!
I set something up last year with the C-more.
I simply had 6 recipes with about 40 digital bits to set.
So I just set one of 6 bits with a P.B. on the C-More, and then moved the recipes stored in the PLC, then reset the bit from the C-More.
I tried to set the recipes in the C-More but had difficulty. The recipe function wasn't fully implemented at the time of my project, that may have changed since then. It really didn't work very well especially the verification part. That is why I implemented it differently.
Hopefully others have had better success.
I'm using C-more 2.78 software. Using a Call Recipe button I want to give the user the ability to edit recipes on the screen. I set the button to...
1,613
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
223
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
125
A project recently went through to replace an old computer that was running Wonderware with a new computer. After a bit of work I was able to get...
485
Hi, is there a way to add modules and submodules in recipes? Because I have several models with different variants each. Or what is the best way...
1,745
