Recommend me a new sensor
dylantzips
Jun 2018
Ohio
27
My plant currently has around 6 sensors that they are planning to phase out. These laser sensors are currently being used to detect wheels on a conveyor and are dependent on reflective tape. The sensors are used to communicate with a robot that hangs the wheels. They want the new sensors to not rely on any reflective surfaces. The new sensor should give a discrete input when the wheel is present.
Any recommendations would be appreciated, as well as any other ideas that you may have!
I do not know the exact distance at this time but it is a very short distance.
"a very short distance" is pretty arbitrary. If you're assembling wheels on a model train, "a very short distance" might mean 1-2mm. If you're assembling wheels on mining equipment, "a very short distance" might be 1-2 feet. You'd need very different sensors to detect the two different scenarios. Can you be a little more specific?
Ok, so I got some measurements:
Rail to rail of the conveyor is 292mm
The conveyor belt itself has a width of ~ 184mm
The wheels we run are either 6" or 8" in diameter.
I was thinking of going the route of the diffuse sensors with background suppression. Could someone find me the best fit for this application?
Thanks!
You are right @ASF, I should have been more specific. I have added measurements. Please check them out!
Good Morning , I have worked with many robot integrators through the years ,and was looking at Pearson Packaging Systems . Have many of you used...
2,206
Hello PLCS.net! I'm about to program my first Robot soon! It's going to be a Fanuc. But wait, there's more! It's also going to be collaborative...
3,362
I need to do some simple schematics, I don't need (and would never use) 3D modelling rendering etc. For those with long memories, AutoSketch would...
20
8,496
Hello all, Is any good analyzing software. We have a bunch of data in text files. Need to analyse. Right now we are using DIadem. Is there any...
2,283
Can someone recommend me a compact device to control logic on/off beacon according to signal from a PIR ? Some RTU maybe. I am newbie in...
2,194
