Recommendations Thin Client / Web Browser
ds7891
Sep 2016
Las Vegas
77
I'm trying to find a cheap solution to deploy a few web browsers attached to the back of LCD monitors.
For testing purposes, my Raspberry PI has been working fine. It has HDMI, Ethernet or wifi, and connections for USB mouse/Keyboard. Which are all the connections I NEED. Plus a basic Chrome/Firefox browser.
I can't justify using the Raspberry PI as a permanent solution. It's going to be used in a commercial application, sold to customers.
My price point is between $100-200.
Any suggestions?
What are your shock&vibe requirements? Temp and humidity? Any certifications for the environment?
$100 - $200 is going to keep you at a consumer grade thin client. Just something to think about.
If not using an industrial thin-client, then I like going with Dell thin-clients (easy, fast order with delivery).
Or, something you can easily get from Best Buy (now and later).
A true thin client should connect to a server hosted session (ex. MS Terminal Server, or VMWare Server). Those are very easy/quick to replace a broken thin-client.
A small PC that runs things locally means extra setup and configuration when you need to replace it later. Basically, don't forget to add in support costs to your price point.
No real shock and vib requirements. It will basically be used on a work desk/office.
I thought of the Dell clients. Since all I am using is a web browser.
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
430
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
169
Hi PLC Gurus - I am new to the PLC programming and configuration world (coming into the space after several years in the energy management system...
130
Hi all, I have been working on a project that requires me to measure the current across a 90 VDC motor of a medical device (similar to an...
26
1,586
Hi Everyone, My company is about to have a meeting to sit down and talk about where we want to head with developing a SCADA and MES system...
893
