Red Lion Animations
CharlesM
Aug 2005
Arkansas
1,129
I'm just getting started with my G3 display. I have a tag that is reading pressure. I have a setpoint on the low end of the scale that is adjustable and an over pressure setting. When the pressure goes over the first adjustable setpoint I want to change the color of the pressure readout. Then if it gets to the over pressure setting I want to change it again. So maybe orange showing that its reached the first then red when it goes over.
When I look at the tag I have a color setting and a setpoint to change this color. However the setpoint is a preset value. This is good for the over pressure but not the adjustable setpoint.
I'm sure this can be done I am just having trouble getting there.
So you want to have it change multiple colors, based on values that are variables?
The built in colors will not help, as they are fixed values. I have attached an example that will allow you to use tags as the limits. I made the colors silver-yellow-red since there is no orange without using a custom color.
I used a program that will accept arguments and return a value in case you need to do this for more than 1 value.
Regards,
Dan
Is this what you mean ?
EDIT: ?!"?£!£!" Beaten to it again by RL !!
EDIT2: Must learn to read - missed part about adjustable pressure setpoints :( !
Dan, I see how your program works but I have one question. When is the program called? I would think there would be an "on-change" or something to tell it when to run.
Dave, Yours will work but its not done with variable setpoints.
Since the program returns a value, it is used for the value of the Color tag.
FYI, to find where a program (or tag) is used you can right-click on the name of the program (or tag) and choose Usage. It will give you a semi-detailed list of where it is being used. This is espcially hepful when values are changing that you think shouldn't be, only to find out you used the wring tag in a program or something.
Regards,
Dan
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
73
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
290
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
297
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
127
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
248
