Red Lion DA10A and OMRON CP1L communication
krzydec
Mar 2020
Rugby
Hello
This is my first post on this forum so I will take this opportunity to say hello to everyone.
I'm new to the PLC programming and communication.
What I want to achieve:
Establish communication between Red Lion DA10A and OMRON CP1L-EM40DR-D using FINS master driver to read data from the PLC and use DA10A to publish information via MQTT.
My setup:
1. OMRON CP1L-EM40DR-D
2. Sixnet switch SL-5ES-1
3. Red Lion DA10A
4. Raspberry Pi 3 B+ (as a WIFI bridge)
5. another Raspberry Pi 3 B+ as a MQTT broker (running mosquitto broker)
What I achieved so far:
Not a lot to be honest, I can ping each device and Raspberry Pi is working as a WIFI bridge. I can ping my MQTT broker from the laptop connected to the switch.
I found a few threads here about the OMRON and Red Lion communication none of them worked for me.
Please can somebody explain me how to perform network configuration using CX-Integrator (Network Integrator screenshot) as I think I have something wrong there.
Then how to configure crimson 3.1 FINS Addresses (PLC1 settings screenshot)
Is there any way of viewing a live data in the Crimson 3.1 to check if the connection between PLC and DA10A is configured correctly?
Finally is there any way of testing my MQTT configuration to check if DA10A configuration is correct. Like creating a tag or program in Crimson 3.1 to publish something on my broker without connecting to the PLC. By doing this I will now that at least this part is working OK.
I'm attaching a screenshots of the configuration.
PS. I'm using CX-progrsmmer to program PLC as this the only software I have an access to.
I will appreciate any help as I spent a bit time working on this with no results.
MQTT tags.PNG Network Settings.PNG PLC1 block1.PNG PLC1 settings.PNG Network integrator.PNG
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
271
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
281
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
115
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
230
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
