Red Lion DSPZR - Download via XCENET Card
jrexrode
Mar 2005
Upstate, South Carolina
106
I have a Red Lion DSPZR with the Ethernet option card (XCENET) installed. While I can access the unit's web page remotely using the address of the XCENET, I was wanting to perform uploads and downloads through this card too. I've setup the XCENET's address in the "Download" tab of the Network section and I've set the Link to TCP/IP, but attempts to extract the program fails.
Are there other settings that I need to change to make this work?
Does the device contain a uploadable image?
Yes it does. I have no problems extracting / updating using the USB port.
Yes, you can upload via the second Ethernet port. Post the configuration if you want some additional help. The card will be Ethernet 2 and needs to be on a different network than Ethernet 1. Also, IP Download needs to be enabled under Remote Update. Set Unit Addressing to Auto Ethernet 2.
Again, if you have tried all this, post your configuration.
Got it. I needed to select the "Auto Ethernet 2" option in the Download tab. I had it selected to "Manual". I previously thought that selecting Auto Ethernet would cause it to auto select and IP address.
Thanks for the lesson.
Good day everyone, bit of a problem, I have a Red Lion DSPZR that I have been working with, yesterday was loading database programs fine, now...
2,006
I've got some screens setup on a DSPZR that I want to view using remote monitoring. The remote monitoring is working great with the exception of...
1,481
We have a DSPZR unit that has quit creating new log files after 2-3 months of working normally. Everything seemed to be working fine with the unit...
2,825
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
117
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
307
