Red Lion G3 Hmi And Gefanuc 9030 Problems
Byron
Apr 2004
Caruthers, California
257
Greetings.
I'm using a new Red Lion G308 HMI with an existing GEFANUC 9030 PLC with a 364 CPU with built in Ethernet. I can communicate with the HMI on the network, program and monitor it as well as the PLC all via the Ethernet network. I can put a data object on the screen and view live data from a register, but I have been unable to figure out how to use push button objects on the screen to turn MBITS on and off.
If anyone out there knows something about this configuration I'd appreciate hearing from you.
Cheers,
Byron K. Sanders- CST SERVICES
[email protected]
If all you need to do is toggle a bit, use the Flag Tag Button tool. (First, in the Data Tags section, make a new flag tag variable and assign it to a PLC bit.)-John
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
110
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
136
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
441
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
639
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,899
