Red Lion G308
pauly
May 2002
South Wales,U.k
244
Any body any idea how to set an alarm or message on a G308 if there is a communications fault with the PLC (CLOGIX)?
I've tried the CommsError internal tag but I'm not sure how to trigger an alarm from an internal tag
I've never used the CommsError variable but I'm pretty sure that you could just put it into a formula flag tag and trigger your alarm from that. Since it's a bitwise variable you'd have to include the bit number for whatever device you're monitoring (i.e. CommsError.1). Or if you just want to know if any comms faults have occurred for the whole system, you could probably assign CommsError to a formula integer tag and use a Data Mismatch alarm with a value of 0 (any value other than zero indicates a comm fault).
Kolur is correct.
Create a new formula integer called say CommsFault and have the tag set to CommsError. Global all ports comms error then use datamismatch alarm value of zero on the alarm tab.
Or use a formula flag tag and then specify the specific bit depending on which device (bottom right of c2 when in comms and your plc is highlighted) the clx is refered to.
To see the error display the commsfault tag on a test page in binary on the G3 and unplug the clx. You could also have a maintenance page showing the comms status, cf status and ip number etc
See attached C2 file for 3 CommsError examples, note you'll have to change the device to your specific one depending on your com port configs. I have not tested or checked this either!
DanYost said:
Thanks gents, I guess I no longer need to monitor this forum...
Regards,
Dan
Dan
You definately do need to monitor these forums
I learnt all i know from you!!
Hi, I am going to try and download a database to a G308 via the serial port. Reading the Crimson 3.0 manual I cannot find anything about port...
2,813
Hi all, I have a customer that wants me to send a email based on a specific event. I have created a trigger that creates a Data File based on...
3,290
Hi everyone, About a year ago I built a panel for a customer that has a ML1400 and Red Lion G308 HMI. He now wants to talk to the PLC with his...
2,756
I am having some fits with my new project. Here are the details of the system: PLC: 1769-L33ER v21.11 RsLogix Studio V21 HMI: G308C100 Crimson...
22
9,468
Is there a way to connect an IP camera to a G308 and use a touchscreen page to view the video? We have a machine with a carriage that moves and...
2,255
