Red Lion G310 mouse
curlyandshemp
Jul 2005
Toronto
1,903
Does anyone know if the G310 can have a moused attached via the USB port to aid with operator navigation?
We are developing a pilot 'canned' package around the G310, and this is one feature a salesman has asked as an optional requirement.
Others must ask the same question, as I know the PV+ can use a USB mouse
I'm fairly certain that the USB port is for upload/download only, so a mouse would probably not work.
It may be possible to connect an old mouse to one of the serial ports and use the raw serial drivers to communicate with it, but it would require lots of programming and kludging and I'm absolutely certain that it's not worth the time and effort.
Yep. I know. The answer is, I'm afraid, no. The USB port on the G3 is a slave only, and can't accept a mouse. Like Koylur says, a serial mouse could be made to work with a lot of work, but I'm not sure it would be a good solution. Sorry. Please feel free to call our Tech Support folks to talk through your application to see if they can figure out another solution for you...
OK
Thanks.
As I stated this was a request put forth by one of our sales guys. Up until a few weeks ago I did not know a PV+ could support a mouse
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,132
Is it possible to print a file from a Red Lion G310 HMI to a networked printer over ethernet?
1,289
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,633
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,641
I currently have RS Logix set up with a ladder logic program, when I force inputs from RS Logix I can get it to update the Red Lion G310 HMI...
2,079
