Red Lion G310 .pdf?
johnfarrugi
Mar 2008
London
99
Can a Red Lion G310 display open pdf or spedific files from a computer on a network? I was looking to display part drawings or maybe operator instructions that would reside on our server. Can these displays do that?
Hello,
The G3 can only display JPEG or BITMAP files. An option may be to store your instructions as a bitmap image. Then using the MakePic utility you could have the images stored on a compact flash card and displayed on the screen.
Jeremy
Nice idea
Post it here as a request :) :) :)
JeremyH said:
Hello,
Jeremy
So you can't retrieve it from a network drive? Only from the compact flash?
You would retrieve it from the CF card, but you can sync the CF card with a pc's directory on the network using the FTP within G3
See here
Then you would need to use the FTPGet command to retrieve the file from the server and put it onto the CF card.
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,139
Is it possible to print a file from a Red Lion G310 HMI to a networked printer over ethernet?
1,291
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,641
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,647
I currently have RS Logix set up with a ladder logic program, when I force inputs from RS Logix I can get it to update the Red Lion G310 HMI...
2,086
