Red Lion G310 to DH+ via Control Logix Bridge
dhunt97
Aug 2011
Clearfield, UT
I have a line of machines all running on AB plcs that communicate with each other via DH+. This line is hooked to our network via the ControlLogix DH+/RIO-EtherNet/IP bridge. I have a 1756-ENBT card and a 1756-DHRIO card plugged into a Control Logix backplane with no processor. This is what is making the bridge from DH+ to Ethernet. I can connect my computer to the network via Ethernet and communicate with any of the DH+ plcs because of this bridge. My question is if I hook a Red Lion G310 HMI to the network via Ethernet, will it be able to communicate with any of the DH+ plcs because of the bridge? I want to use one G310 on the line that will communicate will any of the PLC5s or SLC5/04s that are on the line.
Hello,
This connection will not work as it is. You will need to have a processor in the rack. Our driver communicates to the tags in the PLC to establish communications.
Jeremy
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,144
Is it possible to print a file from a Red Lion G310 HMI to a networked printer over ethernet?
1,292
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,649
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,648
I currently have RS Logix set up with a ladder logic program, when I force inputs from RS Logix I can get it to update the Red Lion G310 HMI...
2,091
