Red Lion Log Files
wdd0422
Nov 2003
100
Hey everybody
I am logging files that I want to view with the web browser, the problem is that they open as text files even though the files are associated with Excell. I have tried it in Chrome, IE and Firefox. Is there a work around for this? I'd like them to open in Excell.
Bill
wouldn't you browse to the file in file manager, right-click, select 'open with', select Excel and make certain that the 'Always use th e selected program to open this file type' is checked?
yes, I do have it set that way. I believe it is the browser telling it to open as text. I cant find anything in the options that will allow me to change that.
Well, at least in IE10, goto Tools / Internet Options/Programs / Set Programs / Associate a file type or protocol with a program. Then select your file type and the default program to open the file with.
IE10 does NOT run Excel in the web browser, but instead starts Excel and opens the file selected.
I believe you have to add your device's IP address to your compatibility view settings. You can access this under the settings icon on the menu bar. (Located directly under the "X" to close the window on my browser)
Hope this helps
Dave
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
298
Hello all. I am struggling with an analog output from a Red Lion Graphite HMI with a GMOUT4 module. I can watch what the data should be (currently...
1,380
I have an automated batching system that im using an analog scale to trigger automated valves to open and close. I have the programming done and...
2,362
Is there any way to set up an alarm tag or something of that nature to log when users log in or out of Factory Talk View Se into the event/alarm...
2,843
Hello, I have configured a Red Lion g3-6 as a thermal profiler...all the operator has to do is push a button on the g6 and it will start logging...
1,766
