Red Lion Remote Viewer
DLMUK
Jun 2013
Southampton
311
I have a Red Lion CSMSTRSX which I have setup the remote viewer so that I can view the screens setup on Crimson 3 on my laptop.
The problem is that when I load up the remote viewer on my laptop (Win 7) I can view it but cannot use any of the press buttons - if I click on them it just does nothing. If I plug in to a XP laptop it works fine.
Has anybody had this issue?
Many thanks,
In Crimson 3, under Web Server, have you set the Remote Control to 'Enable All Control ' or 'Enable Soft Keys only'. If so, what happens if you disable the Win7 Firewall on the remote PC: does it work then (this is a quick check to determine if you need to open a port)?
I usually set it to "Enable All Control" but I have tried it with both settings an no joy.
I have disabled windows firewall in public and home networks - I am unable to do disable domains due to admin restrictions.
Is there anything in the list of allowed programs I can change?
The strange thing is that it did work for about 5 minutes when I first plugged it in but has since stopped.
Cheers,
Individual objects can have remote control enabled/disabled, but if it worked for five minutes, I suspect a network or browser issue. I found that Chrome performs better than IE with remote viewer so trying a different browser may help divide the problem.
Thanks - I tried IE with no joy so I installed firefox with no joy. Installed Chrome and it is working!
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
225
Hi all, I have a client that has a water tank with a loop powered level sensor; the 4-20mA loop goes through a telephone line, half a mile away...
26
6,994
Good day everyone. I'm having problems with using the FTP server on a Graphite HMI. I am using CoreFTP as my client. It works succesfully when...
1,311
I've searched a bit about this topic but they are older threads that I suspect might not cover the tech that's available today. I have a client...
4,935
Hey guys, I am currently trying to set up a CR3000 to be viewed from from any where in the world. I am able to view the HMI locally (across my...
2,160
