Redlion CR3000 Display Emulation in Crimson 3.2
The first time I ran the emulator in 3.2, some version of WinPcap got installed and I just had to allow it, which I did without investigating. It installed that one time and runs fine now when I use the emulator.
Checking from my start menu, it appears that it was version 4.1.2 that got installed. I did not have to install it separately, I just had to click okay.
Red Lion CR3000 Display Emulation with a DA70A Controller
I have a Crimson 3.2 development for each device. i have relinquished the hardware to the panel assembly for field installation, but would like to conduct some further display testing. I have tried to figure out a way to run this in an emulation, but all dead ends.
How do i proceed?
Does your PC have the ability to connect to the PLC(s) that will be used in the application?
If so do these steps first:
On the main menu bar go to Link > Options >
And click on the tick box at the bottom of the dialog box "Send to Emulator".
That will enable the adjacent button Configure for the emulator communication options. If your project communicates using Ethernet, assign the Ethernet Port 1 (or Port 2 if you're using Port 2) to the PC adapter where the PLC can be accessed.
If your project uses the serial ports, you need to know how they are numbered on your hardware which you can find by viewing the Communication setup and highlighting the device and then look at the lower left edge of the software. The emulator has numbers that correspond to all the possible serial ports for any device it can emulate. With serial comms and the emulator, you will have to stop any PLC software drivers that might tie up the PC serial port that you intend to use for the emulator.
Hit okay to close those two windows.​
Ensure the Emulator icon (just to the left of the lightning bolt icon on the menu bar) is toggled on.
Click on the lightning bolt or F9 to update the device (now pointed at the Emulated hardware) with the application.
In the 3.2 Emulator, to close the emulator, you can Click on the emulator icon on the menu bar (just left of the update lightning bolt). To reopen it, just turn the emulator icon back on and hit the lightning bolt.
Note that without having the ability to communicate to the devices, the emulator will show (just like real hardware will) dashes for display values that cannot be retrieved and object animations and states that can't get the source data may appear blank or without colors, etc.
Action On Release command Set(ConveyorPopup,ConveyorPop_1) rejected w/ string tags. SetStringTag(index, data) wants an index. How does one pass...
964
Looking for the object that will provide entry of an integer value for commanding a setpoint in the DA70A ladder logic. Any ideas?
592
Hi everyone. I worked with RedLion HMI several years, in the last year four CR3000 HMI (10 and 15") had have problems with the touchscreen. All...
1,274
My system has an Allen Bradley PLC, Red Lion CR3000 HMI, and a Watlow F4T controller. I am able to read registers from the Watlow F4T via Modbus...
1,643
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
