Redlion Graphite HMI Comms To Prosoft PLX31-EIP-MBS
mark73165
Jul 2008
Texas
24
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull data from a RS485 Modbus device.
I have used many Modbus TCPIP to Modbus RTU converters but first time using Ethernet/IP.
Thanks Mark
The Graphite can't act as an Ethernet/IP client, so I think you will need to use PCCC mode in the Prosoft module and set up the Graphite to treat it as a SLC.
I say that assuming that the HMI is the only device "talking" to the Prosoft gateway. If there is also a Logix5K CPU involved, please elaborate on the setup.
Yes, the G12 has 2 RS485 ports but the issue I have is we have 7 485 Modbus devices to communicate with and 2 of them can only be node 1 and if there is another device on the same daisy chain then the Node 1 devices will respond to other nodes. Tried to get the manufacturer to fix this for years but its not going to happen.
thanks for the comments
Any reason why you chose a Prosoft PLX31-EIP-MBS Ethernet IP device? It looks like an expensive choice and you are making things as hard as possible for yourself. Warning 'not an expert' :) Could you have used one of the RS232 serial ports and then an RS232/RS485 converter. The Graphite seem to be able to talk to most things via whatever port you have available. Or a Modbus TCP to Modbus RTU gateway makes sense, the Graphite can easily speak Modbus TCP. To test a system I had a Graphite talking Modbus TCP to a small Linux computer that was running a Modbus TCP to Modbus RTU program, that was talking Modbus RTU to an ABB VSD, despite my concerns it was easy and worked well.
The company who we purchased the panel from knew what we needed to accomplish but they made a mistake in choosing the type of gateway. We are now using the Moxa 8 port Mgate.
We normally use the Lantronix Xpress DR-IAP which is what most of our customers like.
Hello. I would like to know if anyone here has used the new(er) RedLion Graphite HMI (G15C0000), along with the GRAPHITE MODULE HSPA+ MODULE...
2,674
I have 2 RedLion Graphite HMI's where one is communicating with some remote I/O using Modbus TCP/IP protocol. I have a second Graphite that will...
2,997
Following on from another thread, I just downloaded Crimson 3.2 and it now supports CR and Graphite HMIs. Time for a 'play' :-) It seems to have...
2,030
Been trying for a while to get a flowmeter with Modbus RS485 comms to talk to my Redlion Graphite HMI. Cable has been checked 3 times all good...
874
Our main testing HMI has 2 Ethernet sockets in it. One is setup on IP address 192.168.30.99 and communicates with our main PC network...
748
