reference cam and actual position
seee
Dec 2010
singapor
112
hello dear friends.
The following statements is not my problem and i state it
only for my understanding.
we have a machine which has one axis controlled by
sew movidrive and motor.The axis go to reference position
after each power off and on. I command the axis to
reference travel and after traveling,it stop and hmi panel
display the actual position=880
i power off the machine and move reference cam to right about
1cm and then power on the machine. this time after reference
traveling the hmi display actual position=400
The reference traveling is such that the motor start to
rotate right to pass reference cam then it reverse to find
encoder zero mark then motor stop.
i am curious to know that why after moving reference cam
the actual position change?(however the encoder
has only one zero mark)
For your information in this machine the motor encoder turn
less that 1 revolution (less than 360deg)
thanks.
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
414
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
299
Hey, I'm trying to do the following, I have some experience with Citect but can't seem to figure this out. I/O Tag: BoxPos1_ProdNum (Data Type...
600
OK I'm ashamed that I'm here asking this as I think in 23 years I would have ran into this before. But here we are. Created an AOI to manipulate...
2,013
Studio 5000 & PF 525, Ethernet Comms, Encoder FB, Using Motor RPM as speed reference I'm trying to figure out how to send a speed reference in...
956
