Registers in Machine Expert
Sham
Sep 2019
Australia
152
Hi all,
Another very simple question I have got. How to define register values in Machine Expert? Dont have to use modbus function, but another controller, which knows my M251`s IP address, will be writing to the register value (firs two holding registers).
So, all I want to do is allocate the first two holding registers an address in my GVL (Global Variable List).
How can that be done?
With holdin registers you mean modbus address mapping?
Symbol_name AT %MW0: INT
is syntax for 400001 modbus address on GVL.
What I mean is my device will be acting as slave, whose first two registers will be written a value by the master PLC. All I want is the syntax (hopefully an example can be great too) of giving first two holding registers (of my PLC) memory an address, which I will read later and do the processing. Makes sense?
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
132
Good day guys. I have a third party device with its Modbus registers which I want to copy/set up on a plc because I need to convert my Modbus tcp...
150
Hello everyone, I want to read a register in HC900 honeywell but I am not understanding. https://ibb.co/2dNDsmk In this link are the things I...
1,796
Hi Team, So, what is the correct understanding of the codes for Holding vs Input registers? My understanding was #3 = Input registers & #4 =...
2,564
Howdy Everyone, We have an old HMI that is a UniOp Model eTOP310U201. It is the only one in the plant, and i didn't even know it was here until a...
2,125
