RELAY LOGIC FOR counter value comparison([C1 - C2 ]>= 10)
anoopta47
Aug 2010
kerala
I am working with Mitsubishi A series PLC. I need to execute the logic for counter value comparison ([C1 - C2 ]>= 10). C1 & C2 are two independent counters. I need to produce an out put whenever the difference of the two count values greater than / equal to an integer ( Say 10).
Mitsubishi A series PLC hasn't operator " >= ". So how it be done by relay logic??
Please help me????
:cry:
The mitsubishi has a compare instruction [CMP C1 C2 M100]
The bits M100 M101 M102 are on for one of the following conditions
<, =, > Cant remember which is which off hand as most newer models have in-line comparison however it seems logical M100 = < M101 = = M102 = >.
you can use any bits as long as they are consecutive.
You can use them again providing you use the bit directly after the comparison
i.e.
A X 0.0
CMP
C1
C2
M100
LD M100
Out Y0.0
Look on the mitsi website the manuals are on there
http://www.mitsubishi-automation.co.uk/
I am working with Mitsubishi A series PLC. I need to execute the logic for counter value comparison ([C1 - C2 ]>= 10). C1 & C2 are two independent...
2,565
Not sure I understand the logic here... This picture was taken when the rig was "idle". Why would you energise the trip relay M3 when these...
1,253
Hello all, I have been in maintenance at my plant for 5 years now & progressed through the tiers to become a controls tech through several Allen...
18
6,298
please help i didn't solve this problem with rslogix. I counted but i am not using timer. How i will fix this situation? Please anyone solve this...
18
4,966
Good afternoon colleagues, a pleasure to greet you. In this opportunity I require some help from you. I am trying to make a shift register in...
2,234
