relay messages
b_e33
Mar 2013
lolo
59
If the master is programmed to relay messages, then nodes on the multidrop can engage in virtual slave-to-slave transfers. Half-duplex protocol operates on a multidrop link with all nodes interfaced through half-duplex modems. There may be from 2 to 255 nodes simultaneously connected to a single link.
what is means that master is programmed to relay messages?
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
68
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
129
Hello, I need assistance in making a Relay operation that follows the given parameters: -if S1 is switched and S2 is at off, the Lamp 1 will be...
124
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
459
