Relay Output flash 50 time per minut
kdahlr
Feb 2016
Esbjerg
I have to write in structured text for the first time.
I need a timer/delay there can flash a output relay, on my PLC 50 time per minute. Until it is resat.
Timer1(IN:=Input:=T#2S,Q=>Output1,ET=>Elapsedtime);
But how do i get it to continue until manuel reset or can i use a counter.
Thank you in advance for your help.
Which PLC ?
Also I would use a transistor output and an LED for this, not a relay.
It is a cravis NA-9373 with St-1218 (digital input) and and st-2748 (digital output it is a potential free relay) moduls.
not idea about this plc brand and the program
i guess,maybe OK maybe KO,
Timer1(IN:=NOT Timer2,PT:=T#500mS,)
VarBOOL1 :=Timer1.Q;
Timer2(IN:= VarBOOL1,PT:=T#500mS,)
VarBOOL2 :=Timer2.Q;
To: Sergei Troizky
I now relay have life time, but later the relay output modul will be replaced with a transistor output modul.
The question was more about: how do i make a output timer, there flash 50 time per minute until it is resat in structured text.
To: osmanmom
Cravis PLC is similar to wago plc (Module build PLC).
I tried the timer you suggested and it continue as it should, the problem was I couldn't reset it.
I will keep working on it.
maybe OK maybe KO,
VarBOOL1 :=Timer1.Q & VarBOOL4 & NOT(VarBOOL6);
VarBOOL2 :=Timer2.Q & VarBOOL4 & NOT(VarBOOL6);
VarBOOL4:= (VarINT2 = 0);
VarBOOL6:= (VarINT2 = 1);
VarBOOL7:= (VarINT2 = 2);
CTU001(CU:= VarBOOL3, RESET:=VarBOOL7 , PV:= VarINT1); /*Preset Value = 3, VarBOOL3 pushbutton for RESET Pulse */
VarBOOL5 := CTU001.Q ;
VarINT2 := CTU001.CV;
get yourself the oscat library.
and above method is not accurate (for a lightflash oke)more precise is use a task or use the now() time and %2.
count the pulses in 100 minutes to see what is wrong with it. (it is because the timers need time to setup.
reset can only be done by stopping the input. have a look at the TP timer in util.lib.
btw it is codesys.
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
132
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,619
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,893
Troubleshooting a Eaton Easy719-AC-RCX. Have three digital inputs and one relay output. PLC input power 120VAC. Each digital input has a 120VAC...
2,036
Hi all, A client is asking if I can move a motion sensor from an existing alarm dialer to a PLC discrete input. Looking up the datasheet, it...
2,324
