relay voltages
LtuMichJoe
Mar 2005
please rank the voltages in order from highest to lowest
Pull-In, Drop-Out, Hold-In
I know that Pull-In Voltage is always higher than Drop-Out, but I'm not sure if Hold-In voltage is higher than both, lower than both or right in the middle.
thanks
Its in the middle ..... not enough to pull in and more than enough to keep the actuator in place ..... too low and it drops.
Is it against code to mix voltages within one force guided relay? I have a force guided relay with a 24 VDC coil. This relay has five normally...
3,630
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
53
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
123
Hello, I need assistance in making a Relay operation that follows the given parameters: -if S1 is switched and S2 is at off, the Lamp 1 will be...
121
