rem mem prog state in ControlLogix
b_e33
Mar 2013
lolo
59
can any one know what r the statuses in this controller?
i try to find a manuel that will explane the rem mem prog
but didnt find
can some one explan this to me? :)
Can any one [explain] what the [keyswitch states] are in this controller?
I [have tried] to find a manual that will explain the "Rem", "Prog", and "Run" states but have not found one.
Can someone explain this to me ?
Modern Allen-Bradley controllers use a keyswitch or toggle switch on the controller to select the operational mode of the controller.
"Program" mode does not execute the user program. It allows editing of the program and monitoring of the data table, but the user program does not execute and all of the outputs remain in Idle mode.
"Run" mode executes the user program.
"Remote Program" and "Remote Run" indicate that the controller is in Program or Remote mode, but the keyswitch is in the intermediate "Remote" position. That position allows RSLogix software to control the Program or Run mode of the controller.
If the keyswitch is all the way in PROG mode, RSLogix cannot place the controller in RUN mode.
If the keyswitch is all the way in RUN mode, RSLogix cannot place the controller in PROG mode and edits cannot be made to the controller.
Placing the keyswitch into the RUN position is sometimes called "Hard RUN" mode. It's the easiest way to assure that program edits cannot be made to the controller.
Hello All, I need to program a ZEN V2 relay for a correct two switch sequence to give one out put e.g. switch sequence 1 then 2 I get an output...
2,730
Hello all , i just bought a plc 5 ,and changing the key lock switch does not put the processor in either run or program mode. I can only do this...
3,183
Can someone tell me if it is okay to switch from RUN to REM while a piece of equipment is being controlled by the PLC, or do I need to shut the...
4,108
How to use Pythagoras theorem in cicode, I want to make triangle calculation like this: a2 + b2 = c2 I want to find out the size of the C but I...
2,341
I have this SLC 500 running a pretty vital piece of equipment, and it's in RUN... What I want to know is, if I turn the key to REM so I can hook...
3,576
