Replace DH485 Network with Fibre
JElder
Apr 2011
Aberdeen
23
Good morning,
I have a plant site that has several PLC's communicating over DH485.
The site is due to receive some new equipment and there have been constant problems with the DH485 network since day one so the site is to be brought up to the clients latest specification which is fibre.
The PLC's are all SLC5/03's.
Would the best method be to utilise 1761-NET-ENI modules with each PLC then Ethernet to Fibre Media Converters?
Regards,
Good morning, I have a plant site that has several PLC's communicating over DH485. The site is due to receive some new equipment and there have...
2,947
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
77
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,266
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,596
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,513
