Replace QuickPanel View - CF Card Only?
keithkyll
Jul 2005
Heath, TX
2,033
Replacing QuickPanel View IC754VSI06MTD. Have Proficy ME 7.0.
Old panel has damaged touchpad. Tried to connect via Ethernet crossover, and Ethernet switch. Might be my laptop's port.
What address should I use? Old unit has 192.168.1.20. Nothing in Subnet or Gateway.
I tried 10.0.0.2 with Subnet 255.255.255.0.
No luck with ping. I can see lights flashing on hub switch and HMI.
How do I know if the files needed for upload are in the old unit?
Is CF card the only way? What kind of CF card do I need? GE manual suggests a list of compatible cards, but website only lists the GE version.
To be sure of a compatable CF card get one from GEIP. I know that the ones from Red Lion work too.
If you did not load the original program to be uploaded there is about a 50% chance that it cannot be uploaded.
There are two ways to find the IP address either through the Network utility on the QP or by opening a backup of the project from the developer. A third should be by reading the documentation that the developer wrote, but that is sometimes lacking. :(
The CF card may be the most reliable, if it still boots and the touch screen works. It is also a good, cheap place to keep a backup. The drawback is that you must have the exact same model QP to restore it to and you cannot pull it from the CF into PME for editing. You need a PME backup for that, it's a security thing I am told.
Thank you. Any issues with addressing? Do you need numbers in subnet and gateway? Preferred setup?
No addressing issues that I know of, just make sure there are no duplicates.
Need subnet, usually 255.255.255.0 gateway is needed only if there is one that you need to get through. Check with whoever setup that network.
Preferred setup is the one that is identical to the old unit. For this access the backup or documentation from the developers.
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
74
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,259
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,572
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,520
