reports Print
kumar satyam
Oct 2011
hyderabad
30
Hi All,
I have a requirement of saving reports in a locked/uneditable format .
Is it possible through our logic??
I can generate a CSV the only thing is i want to convert it to PDF .
Advance thanks for Help
Hello,
You do not say which HMI/SCADA/software you are using.
PeakHMI can output reports to PDF. PDF files can still be edited with the right software.
Output the report to a printer, a hard printout, is really the only way to make a report "locked".
I have used XLReporter for several years with great success, go to www.sytech.com and download your evaluation.
It will run for two hours but that will be enough to test everything, it has a pdf converter and can handle automatic emails to send your reports.
You will need your OPC server at hand.
si'm looking for a small,inexpensive, touchpanel HMI that can connect to a printer to print simple text reports. The HMI will read data from a...
2,223
The question of our customer: After a cleaning process (23 steps) he wants to have a report of that process. This has to contain the 23 logged...
3,123
How do you get a SLC File or Report to export to a .doc file? OR can a File/Report be stored in a format that can be read by Word? Thanks Tadg
4,016
Hello Everyone, I am working on reports in Vijeo Citect V7.40. I want to generate a report whenever I press the button. I am able to generate it...
882
Any advice on below issue? ➢ IFix 5.0 with USB Hardware Dongle License Standalone application connected to RX3i PLC units via Ethernet (bridged...
1,632
